compression ratio vs psi
Car: 88 GTA "Cocaine"
Engine: 350 tpi
shouldnt we be able to determine what the comp ratio is by the psi on the compression tester
Re: compression ratio vs psi
No.
There are a number of reasons... leakage, different cam profiles that cause a variation in how much compression is actually captured, the fact that compression is more or less an adiabatic process except that there's variables in how much heat escapes during the process, etc. etc. etc.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
No but the test result from a cranking compression test can be used as a "guideline" to indicate what the motor will need for fuel octane.
180ish PSI is usable on pump gas.
over 200psi gets a little too dicey.
130 psi is okay ... ?
If all 8 are the same within 10 psi or so, and the motor runs right, then yes.
If of course, the test was performed properly.
A motor that actually had that little compression would have trouble running, unless this is an all-out race piece. Which is why I feel that it's necessary to add that little qualifier.
130, 200, block, calculating, chevy, compresion, compression, copmpression, f350, psi, ratio, reatio, small, test, vs
