Surging then choking
Old Jan 6, 2008 | 12:22 PM
Slavic38's Avatar
Hi, I don't have a third gen, but my 21ft motor house has the same engine and it's in trouble so I was hoping some of You would be willing to give me some pointers.
BTW, I stumbled on this board after I bought it and researched about the engine and found great info on a PROMinator which would allow me to be able to switch to a "cruise mode" on highway to save gas.
When I bought it there were black drops and smoke from the exhaust and smelled like the mixture was heavy. Not much smoke, but black. Check engine light was on. I used the paper clip test before I bought it and found that the O2 sensor was bad. The previous owner said engine was rebuilt recently due to water in engine. It ran fine for about 50-60 miles.
I put stabil gas additive cause I knew it's going to be sitting and ran it for a while after adding that to the tank.
Then it started surging the next time I started it. It stopped surging after a while when it wormed up. It was sitting for a while, then I moved it to a new parking/storage spot. Surged at first then we moved it 10 miles or so.
Then when I was parking it in it started cutting out and not reving when I press the gas pedal.
I changed the O2 sensor, but that didn't fix it.
Now it has trouble starting. It takes a few tries to start it and when it starts It doesn't rev when I pres the gas pedal. It would turn on and stutter for a while not responding to the pressing and letting go of the gas pedal and then just cuts of after a while.
The owner said I should change the fuel filter and that's my best guess right now.
Thanks!
92camaro350cci
Oct 14, 2015 09:29 AM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
banksGTA
Sep 13, 2015 11:56 AM
