how much hp ?????
Old Jan 7, 2008 | 11:01 PM
peter355camaro's Avatar
how much hp ?????
hy everybody!
i have a 1982 chevy camaro with a 355 waiting to be instaled. i have a question for you guys! how much hp i can get with this combo? sonds like this:
3970010 2 bolt block ,cast crank , aluminum pistons
compcam 280h hydraulic cam with 480 lift on int./ exh. 230 duration at 0.50 on both sides and 110 lobe separation.
3973370 heads (from a 1969 camaro 350/300hp) ported heads with 1.94/1.50 valves
2101 edelbrock intake and a 750 holley double pump vacum secondary carb!!
and also i would like to know what torque converter should i run and what rear end? (im thinking 3.73's)
the car is for daily drive and sometimes get it on the strip!
any help apreciated ...THANKS!!!
Old Jan 12, 2008 | 01:05 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: how much hp ?????
I would guess around 350-375, more or less depending on what has been done to the heads and the compression. I would have to say a 650 might be a better choice for carbs. It's a matter of making parts work together. A 650 carb and 3,000 rpm stall it should be a pretty quick ride. For the street 3.42 gears with that overdrive work good for me, and i can still cruise at 90.
