help getting a keyway pulley on!
Old Jan 12, 2008 | 02:01 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
All the kits I see are for the press-on P/S pulley..I now have the key-way pulley....how do I get it on my key-way pump shaft? Is there a specific tool I need to get?
Old Jan 12, 2008 | 07:42 PM
Damon's Avatar
Re: help getting a keyway pulley on!
Press-on pulleys have a collar that the jaws clamp onto to get a grip on it (so it pulls out on the pulley when you tighten the center bolt). If you have an earlier pump I don't think the pulley shaft has this same collar and so you can't use the same tool to remove it.
Old Jan 12, 2008 | 09:41 PM
wdigitog's Avatar
Yes I know...I have the press-on tool...I just need to know what I need to get the keyway pulley on a keyway shaft...........
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
evilstuie
Sep 24, 2015 02:31 AM
