tbi serpintine with Vortec heads??
Old Jan 13, 2008 | 11:36 AM
KyleDallas's Avatar
Found a sweet deal on some local Vortecs... I'd like to use them but
this is a LOW buck build on a 350 Throttle Body.... 1991 Suburban..
I need to know if the Vortecs accessory holes will work with my
stock serpintine accessories, brackets... etc..
If they won't fit with the accesories I currently have... Im not getting
them..
I've got a manifold lined up if they will work with my factory accesories..
Old Jan 13, 2008 | 01:53 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: tbi serpintine with Vortec heads??
yeah man it fit fine on my L03 when I did that project.
Feb 2004:
Attached Thumbnails tbi serpintine with Vortec heads??-proj19.jpg   tbi serpintine with Vortec heads??-proj20.jpg
Old Jan 13, 2008 | 01:54 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
OH but be aware you need a new intake manifold
Vortec heads have a different bolt pattern and gasket style for their intake.
Old Jan 13, 2008 | 02:41 PM
KyleDallas's Avatar
Yep.. knew that... thanks for the info on the accessory/bracket question
Old Jan 13, 2008 | 10:55 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
All the accessory holes are the same, so the bracketry should match up just fine. Just need to get a Vortec style intake. DO NOT get one of those intakes that claim to have bolt patterns for a regular SBC head and Vortec head - the bolt pattern AND the port dimensions/locations are different. Get a Vortec-specific manifold.
Good luck!
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
