85 camaro 2.8l no spark
Old Jan 14, 2008 | 12:54 AM
Heartless's Avatar
Transmission: TH-350 + Shift Kit + Megashifter
Axle/Gears: Standard 3.08 open fat tires
Ok, I have an 85 camaro with a 2.8l (automatic). I'm not getting any spark at all. I have replaced the ignition control module and pickup coil. I tryed a new coil but I never bolted it in just had it sitting there. I have the 12v when key is on, and when I have a test light connected the light is light til I go to start it then It goes out til i turn the key off. Any ideas?
Thanks!
Old Jan 15, 2008 | 01:16 PM
epic612's Avatar
Car: 1989 Firebird
Engine: 3.1L MPFI V6
Transmission: automatic
Re: 85 camaro 2.8l no spark
pretty sure i've run into the same problem right now. if so, it's the timing chain.
Old Jan 16, 2008 | 06:45 AM
Heartless's Avatar
Actually, I already installed a brand new timing set (marks lined up), but I'm not getting any spark from the coil period! I'm not sure, I tryed a new one but didn't bolt it in, I wasn't sure if it needed to be grounded or not. Someone said it could be the ignition switch but I don't know how to test that. I'm lost, I've bought the new parts and I'm getting no where. I know the two circuit breakers are not there on the fuse panel and I was wondering if they made a difference and if there were any fuses under the hood that could be cuasing me not to have spark.
Old Jan 18, 2008 | 08:30 PM
Heartless's Avatar
Necer mind, I figured it out. The ignition module wasn't getting a good ground
92camaroJoe
Jul 29, 2023 07:57 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
BurlyChev
Aug 16, 2015 09:08 PM
92camaroJoe
Aug 13, 2015 06:07 AM
