vacuum lines????
Old Jan 15, 2008 | 07:10 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
vacuum lines????
i gess i put this in the wrong place to start with so here i am my stuff has been apart for awile and my chilton manual has a very poor drawing for the vac lines ? where does the fpr get its vac from?? what is the hvac does it have to two small hard plastic lines and where do thay go the rest i can get i hope my car is 88iroc/ tpi/ auto thanks for any help
Old Jan 16, 2008 | 08:44 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: vacuum lines????
One line goes to the bypass valve (allowing hot water into the heater core) and the other is vacuum to run all the HVAC controls from. It doesn't matter what port you get it from, it's full manifold vacuum. I believe the bypass valve one comes out of a wire bundle by the evaporator box and the other by the wiper motor.
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
