Automatic Antenna
Old Jan 16, 2008 | 09:47 AM
SKYROC's Avatar
Automatic Antenna
I was out exercise driving my 87' and turned the radio on. When I got back to the garage I turned off the engine but started hear a buzzing sound coming from under the hood, just under where the automatic antenna recesses behind the right front quarter panel.
I turned the radio off and the antenna came down but the antenna motor never shut off. Fortunately I have the battery rigged up on a kill switch but now, when I start her, the antenna will not come up when I turn on the radio and, if I leave the radio off, the motor continues to run trying to stow the antenna even though it is already stowed.
Old Jan 16, 2008 | 09:54 AM
SKYROC's Avatar
Re: Automatic Antenna
Are any thirdgen owners aware of a quick fix for my ailing antenna?
Old Jan 16, 2008 | 10:05 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. The relay (unhook it and the motor will stop) is under the pass side of the dash. A fix kit is available from GM, I believe. A search will probably find the above part number. FYI, I replaced the whole assembly, which I purchased from GM, a couple of years ago. I don't know if the piece has been discontinued or not. GM 22062580.
JamesC
Old Jan 16, 2008 | 10:14 AM
SKYROC's Avatar
Thanks JamesC. Is the relay labeled?
I'm gonna run out to the garage and look for it now.
Old Jan 16, 2008 | 11:55 AM
MariahFan's Avatar
Car: 86 Z28
Engine: '76 305 0.030 over
I don't remember the connection being labeled, but it's been about 13 years since I worked on mine...
There's a little plastic line that fits inside the metal antenna shaft that winds up onto a spool inside the motor that is broken. IMO, its probably easier just to replace the whole unit. It's kind've a tight fit up under the fender, but just pop out the inner fender well and you should be able to swap the antenna out.
Old Jan 16, 2008 | 12:24 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Ordered my antenna unit from GM parts direct a few
months ago that was suppose to be a direct replacement
for our cars. It wasn't Its universal.
Had to fab up a new bracket. Plumbers strap.
Easy to do. 3 wires colorcoded rite, just cut and
splice in. Works great
They also had a repair kit for broken band as yours is.
Relay should be under middle of pass dash bottom lip as both 87s.
HTH
Later
Old Jan 16, 2008 | 03:33 PM
SKYROC's Avatar
Thanks for the info...sounds like a good weekend job.
Old Jan 16, 2008 | 04:56 PM
jaykar's Avatar
Pulling the wheel and inner fender and even having
to fab up a bracket if needed shouldn't take 3 or 4
hours with (kool Aid) breaks in between
Later
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
