Continue my cheap 355 build
OK I am looking to you to help continue my 355 build, so far I have the stock 4 bolt main short block together with speed pro L2252af30 dome pistons installed but no cam. this will be a limited use street/strip engine cruise car and I am looking for suggestions to complete this lower dollar build and I want to stay with a hyd cam, FYI this combo with 64 c heads will yeald 11.87-1 comp, any suggestions will be appreciated thanks.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Continue my cheap 355 build
Why would you run dome pistons and 76cc heads? That's a terrible combo. Sell the pistons and get the right ones for your app.
What is your budget now, and what results do you want? I guess you're looking for heads and cam now?
Hotrodboba400
Dec 10, 2019 07:07 PM
Billy Decker
Sep 4, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
