Fuel System Questions
Old Jan 16, 2008 | 10:43 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Well, I finally got a good look at my fuel lines. They are rusted pretty bad so I decided I am going to replace them since everything is off the car anyways.
My question is, how feasible would it be to make my own lines rather than buying prebent lines (kinda pricey at $70 a piece x3)? I was having a look at Jegs for some lines and end fittings, but I am new with all of this and am not sure what I would need.
Would this line be able to handle the TPI line PSI (since the Jegs aluminum line only handles 25 PSI): http://www.jegs.com/webapp/wcs/store...47184_-1_10019
Also, are these the fittings what I would need (I keep hearing stuff about the AN fittings but am kinda lost): http://www.jegs.com/webapp/wcs/store...52556_-1_10019
Thanks in advance for any help.
Old Jan 16, 2008 | 11:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel System Questions
Those fittings are for hose, you'd need something for tubing.
MustangBeater20
Oct 29, 2022 09:20 PM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
redmaroz
Aug 16, 2015 11:40 PM
