dipstick broke
Old Jan 18, 2008 | 11:33 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
dipstick broke
I was a quart low and went to wally to get some oil.
put the oil in at the parking lot and drove to the carwash
when I pulled in the motor started to make noise so I got under the hood and I dont know how i knew but I went right to the dipstick
it was really hard to pull out but when I got it out it was all bent up and part of it is hopefully in the tube
has anyone ever heard of this happening
Old Jan 19, 2008 | 08:37 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: dipstick broke
Its rare, but it happens. You might be able to pull out the dipstick tube, and hope the rest of the dipstick is in there. My guess would be though, that the rest is either on the bottom of the oil pan, or, wrapped around the crank somewhere. (though, not as likely....) How much is gone?
Old Jan 19, 2008 | 09:24 AM
jamon8's Avatar
Engine: 350 tpi
Re: dipstick broke
it broke at the full mark
Old Jan 19, 2008 | 09:28 AM
ploegi's Avatar
Engine: 5.7 TPI
Re: dipstick broke
That sucks......
Try and remove the dipstick tube, and see how much of the dipstick is in the tube. (have a new one right there handy, they are dirt cheap at the parts store, although, I am unsure if you can get anything other than chrome..... There will be a bolt thru a tab on the dipstick, to hold it in, BUT, make sure you pull it STRAIGHT!!!! out. If it breaks off in there, that is no fun at all. Maybe wanna hit it with some PB blaster before ya try and pull it.
Old Jan 19, 2008 | 10:57 AM
jamon8's Avatar
Engine: 350 tpi
Re: dipstick broke
I allready pulled it out and it broke
I hope the other piece is in the tube or I will have to take the pan down
Old Jan 19, 2008 | 08:33 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: dipstick broke
Get one of those $2 telescoping magnetic pick-up tools, drain the oil pan, and stick it in there and fish around - see if you can pull anything out that may have fallen in. Could do the same down the dipstick tube hole.
Old Jan 19, 2008 | 08:54 PM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
Re: dipstick broke
That sucks. Ya try the magnet thing first
Bubbajones_ya
Oct 25, 2015 08:01 PM
NZKnight
Oct 15, 2015 02:47 PM
wanext
Oct 6, 2015 12:18 AM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
