Fuel Tank keeps sagging lower......
Old Jan 19, 2008 | 10:28 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Over the past two years, I've noticed when I'm putting fuel in the gas tank nozzle, that the nozzle keeps slowly lowering in the gas door opening. Now the fuel fill pipe is resting at the bottom and I can barely get the gas pump nozzle in. I don't seem to have any broken straps or pulled bolts, but something's gotta be happening. Anyone ever experience this?????? Nitro
Old Jan 19, 2008 | 11:07 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: Fuel Tank keeps sagging lower......
Just take a look at everything to see if anything is rusted or about to break.
Old Jan 19, 2008 | 11:19 PM
car_fixer's Avatar
the filler neck just kind of hangs out of the side of the tank and isnt supported well, you could probably pull the little plastic cover in the rear wheel well and push it back up if it isnt rusted.
Old Jan 19, 2008 | 11:32 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
I had to have my tank dropped a few months ago and I guess it got bent when they did it so now it sits down there too, i will try and do what the other guy suggested when I get time and see if it sits back up.
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
