What happens if you install a cam this way...
Old Jan 24, 2008 | 02:49 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Just curious. I know they should be installed dot to dot, but I wonder what will happen if they are installed like this in the picture. Thanks fellas.
Will
Attached Thumbnails What happens if you install a cam this way...-dscn2908.jpg
Old Jan 24, 2008 | 02:59 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: What happens if you install a cam this way...
Everything works correctly. You put in the distributor and go.
Dot to dot means you have to rotate it one full turn (until it looks like this) to be on #1 firing.
IIRC!
Old Jan 24, 2008 | 03:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What happens is you're more likely to get it one tooth off.
Install dot-to-dot, then rotate the crank one turn to get to the #1 firing position. As pictured, the engine is in the #1 firing position.
Old Jan 25, 2008 | 02:42 PM
pairtoe's Avatar
yeah def install dot to dot i learned this the hard way, and got it a tooth off and had to tear it all down just to do it again.
Old Jan 25, 2008 | 07:27 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
or you can install it dot to dot then degree your mess, and get it perfect not just moderatly close.
~Couch
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
