What is wrong with my car.
Old Jan 28, 2008 | 07:12 PM
Shadowman's Avatar
Car: 1989 Pontiac Firebird Formula
Engine: 305 TBI
Axle/Gears: Stock Gears
Ok my problem is sometimes when I start my car the idle serges up to 1500 rpm and back down to where it almost kills the engine. Its died on me on 2 seperate occasions. It does this for about 45 seconds then idles back to normal. When it starts to do it I usually press on the gas to keep it running and it stutters a bit until she clears her throat. I have no check engine light and it seems to run strong after I take off. Its a stock 305 with 88,000 miles on it. Would a tuneup help or is it maybe the IAC Valve? Any help would be great. Thanks
Old Jan 28, 2008 | 07:29 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: What is wrong with my car.
kinda my problem, except some of the time i got to pres my gas down to start mine, and hold it for a few, or else it will not start, (305 TBI) im thinking IAC on mine also
Old Jan 28, 2008 | 07:47 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
this might help you. check out the tech articles...
https://www.thirdgen.org/tpimod2
Old Jan 28, 2008 | 07:53 PM
Shadowman's Avatar
Engine: 305 TBI
Whats really weird though is it only seems to do it if I drive some where then turn it off then come back out and start it up 30 minutes later. It never seems to do it in the morning when its cold after it set overnight.
Dyno Don
Jan 24, 2016 08:24 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
