A/C compressor, will an 88 fit in a 90?
Old Jan 29, 2008 | 05:20 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Anyone know if the A/C compressor off a 88 Iroc-z L03 305 v8 will work in a 1990 GTA with the L98? They both look very similar.
Thanks.
Old Jan 29, 2008 | 06:18 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: A/C compressor, will an 88 fit in a 90?
if you are looking for one, i just took all of my a/c stuff out of my car and it was replaced by the previous owner less than 6 months ago. i will let it go for pretty cheap. its off an '85.
Old Jan 29, 2008 | 06:43 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I have found one, off the 88 but the part numbers are different. They are both harrison compressors. I cannot find anything on the net that says if they are interchangeable.
Old Jan 31, 2008 | 10:31 PM
fignewton's Avatar
Car: 1984 Z28
Engine: .030 over 350 4 bolt .480/292 cam
Transmission: Tremec TKO 600
Axle/Gears: 3.27:1 posi
They should be virtually identical. Just check the number of grooves in the pulley. Worst case you can swap the clutch assemblies from one to the other.
evilstuie
Apr 14, 2016 08:52 PM
New2Chevy
Sep 28, 2015 12:35 AM
zayne0
Aug 24, 2015 07:22 PM
Thaney9
Aug 7, 2015 08:25 PM
