LTX Quick Timing question
Old Jan 31, 2008 | 08:34 AM
1985z28FordKila's Avatar
is settig the timing for the lt1 same as any other distributed motor?. i am guessing it is i just wanna make sure, cuase if it is the same then i good haha.
Thankx for your time
Old Jan 31, 2008 | 12:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: LTX Quick Timing question
Does said LT1 still have the Optispark distributor, or has it been converted to run a tradiational distributor behind the intake?
If its got the Opti, then its not adjustable. The ECM makes all the adjustments.
If its been converted to a tradiational distributor, then you adjust timing by rotating it clockwise/counter-clockwise just like a normal SBC.
Old Jan 31, 2008 | 11:05 PM
um it is the one mounted on the front of the timing chain cover so i am guessing the opi one so it Corrests the timing it self Aswome
Old Feb 1, 2008 | 08:17 PM
Air_Adam's Avatar
On the timing cover is the Optispark, yes. Its not mechanically adjustable - only the ECM can adjust timing.
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
