spark plug melted
Old Jan 31, 2008 | 04:50 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
spark plug melted
so i pulled all my plugs with my motor today and found that my rear driver side plug was melted. all the other plugs looked brand new. this was on a bolt on LO3 that has run as much as a 150 shot and a consistent 125 shot of nitrous. the ngk plugs are 2 step colder plugs. basically im just curious on what im going to find in that cylinder when i pull the head tomorrow. anybody wanna guess? heres some pictures of the plug sorry about quality its from my phone.
Old Jan 31, 2008 | 05:28 PM
danandamy's Avatar
Car: 86 Camaro
Re: spark plug melted
Wow, that cylinder was waaaaay lean. I'm betting the piston is going to look fugly!
Old Jan 31, 2008 | 05:35 PM
Reputation7's Avatar
dude your plug is weaksauce.
you wanna hear some poz stories?
edit: 50+ bottles of 150 shot 170k mile 305 still going strong.
and mine setup looks cooler than yours.
Old Jan 31, 2008 | 07:32 PM
Damon's Avatar
One thing from the get-go here: DON'T use projected-nose spark plugs with nitrous or boosted applications. WAY too easy to overheat the tip and side electrode under WOT conditions on squeeze/spray. Colder doesn't help if the heat can't get down the side or center electrode fast enough. The result is detonation- yes, bad choice of plug can CAUSE detonation, even pre-ignition, even if the heat range is plenty cold. Standard non-projected nose plugs a couple ranges colder than stock and gapped around .035 are what you want. 'Nuf said on that subject.
Other than that, it looks like you ran it lean and/or got too aggressive with the spark advance. End/back cylinders on a SBC are usually the first ones to go lean. Your pistons will be the next to take the abuse. Back your spark down a few degrees and make absolutely certain your fuel pump is keeping up throughout the entire quarter mile run (no fuel pressure "slumping" in the higher RPMs).
Old Jan 31, 2008 | 08:21 PM
my nitrous solenoid stuck open.
literally EVEYRONE uses the ngk tr6s as a nitrous plug.
at about 105 mph, my stock tbi pump (170k miles) would drop about half a psi while spraying. timing was at 3* advanced on the 150 shot too. never had any trouble with it.
Old Jan 31, 2008 | 10:21 PM
turbo pics just for the hell of it.
Old Jan 31, 2008 | 10:42 PM
Engine: LO3
im going to replace these plugs with the tr-6s everyone has success using. also this was the only one that went bad all the other plugs looked like they should for a good running motor. i did have the stock tbi fuel pump running over a 150 shot so maybe it ran out of fuel at higher rpms or something. also i ran a 125 at stock 0 degrees of timing. im still just afraid as to what ill see when i pull the head on that side tomorrow.
Old Feb 1, 2008 | 12:32 PM
why are you pulling the head? did you NOT see my plug with a pool of molten metal where the g/s used to be? i sprayed 10 more bottles through the car before i took everything out for the turbo 350 swap.
Old Feb 1, 2008 | 05:05 PM
danandamy's Avatar
Car: 86 Camaro
If you don't want to pull the head you could always do a compression test and that'll tell you where you're at for sure.
Old Feb 1, 2008 | 06:36 PM
OR he could just quit bein a sissy and run its ***** off and not worry about it.
Old Feb 1, 2008 | 07:07 PM
Engine: LO3
no i just didnt want to pull the head because i didnt wanna see any damage if any. but i pulled the heads today and everything was mint and clean in there man are 305 ****in champs. new gaskets, cam, head porting and shell be better than new.
Old Feb 1, 2008 | 08:36 PM
dont suppose you looked at the rings.... cuz you know.. they go before the pistons in this situation....
oh btw more turbo pictures.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
