1991 Camaro problem starting
Old Feb 3, 2008 | 05:08 PM
RedWind's Avatar
Car: 1991 Chevy Camaro RS
Engine: Stock V6 3.1L MFI
Transmission: Stock Automatic
I just bought this car and it ran perfectly for about a day then it starting cutting out, and then it got worse and when I would push on the gas more then just a tiny bit it would start to cut out until I would let off, now it wont even turn over, I checked the spark and it good I changed the filter and thats good, I check the pressure and that is also good, now I am stumped it went everything seems to be fine but it wont turn over.
Old Feb 3, 2008 | 08:29 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: 1991 Camaro problem starting
im confused how did you check for spark if it wont turn over?is this a tpi or tbi or carbed engine?vats will keep it from cranking over, take the key out for 5 minutes put it back in and try it if you havent done this anyway. give a little more info, well be glad to help,later jimmy
Old Feb 3, 2008 | 09:11 PM
RedWind's Avatar
I pulled the wire off stuck off the solenoid and watched it spark there the I took a wire off the spark plug stuck a screw drive in it and let it arch onto the engine. as I had some trying to turn it over. and I am not sure what the diff is between a tpi and a tbi engine. and I have tried the wait 5 thing. also ever once in a while it will turn over with a fresh charge on the battery, and when it does if I just tap the pedal it will cut out, but when I hold it for about half a sec it wont cut out.
Old Feb 4, 2008 | 01:28 PM
RedWind's Avatar
sorry for double post
alright now it is starting but when I go to rev it up it chokes out you will feel it accelerate and then the acceleration will cut out and then the engine will cut out.
Old Feb 9, 2008 | 07:59 PM
RedWind's Avatar
Update:
I did a tune up, and filled my tank and added water remover and I got it to run now, but when I rev it up and around 2500 it starts missing and lights pulse with the miss.
92camaroJoe
Jul 29, 2023 07:57 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
