metal on metal noise then tries to die
Old Feb 4, 2008 | 10:55 PM
Bo1226's Avatar
Car: 83 Z28 modified 350
Ok, I have very limited info here but wondering if someone can give me place to start??? My father called me and told me his car has some serious issues and told me the following: Was driving down highway and started making a popping sound (possibly backfire but not sure), Oil pressure stayed good as well as temp. Got it home about 10 miles and popped the hood, at idle it would make a metal on metal noise maybe every 10 seconds and almost die, but other than that would idle fine. Has me stumped why the noise would be only ever 10 sec or so and when it does it then it comes close to dieing. Any ideas would be appreciated. The motor is a mid 70's 350 pretty much stock other than RV cam, edelbrock intake and carb, headers, high volume oil pump, double roller timing.
Old Feb 4, 2008 | 11:07 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: metal on metal noise then tries to die
Broken Valve Spring?? Loose bolt on the flywheel/flexplate?
Can you go see the car? OR, is it too far away....
Old Feb 4, 2008 | 11:11 PM
Bo1226's Avatar
I'm gonna try and go tomorrow if weather permits. I was leaning toward valve spring to start with but just had me perplexed that noise was so intermittent and then it would try and die.
Old Feb 5, 2008 | 11:21 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I would pull off the valve covers and inspect the valve train for starters.
Old Feb 5, 2008 | 04:19 PM
danandamy's Avatar
Car: 86 Camaro
May be something as simple as a belt driven accessory trying to lock up and you're hearing the bearing trying to sieze. May not be but I'd start with the simple stuff first.
Old Feb 5, 2008 | 04:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Does the car have A/C?
Old Feb 6, 2008 | 02:01 AM
Bo1226's Avatar
Thanks for replies guys....No it doesnt have AC. Any more suggestions??? I'm gonna start with valve train and go from there, but would like to hear any other suggestions.
RedLeader289
May 28, 2019 01:47 PM
MrPackstin
Oct 25, 2017 08:09 PM
ironbmt
Sep 27, 2015 06:00 AM
Lmancha96
Sep 25, 2015 08:11 PM
