Coolant Leak On Harmonic Balancer Pulley...
Old Feb 5, 2008 | 10:20 AM
Shookum2004's Avatar
Car: 1988 Camaro SC
Engine: 2.8v6
Transmission: 5spd manual
After a woe of cooling issues, I have yet another.
The other day I noticed a small leak under the engine, and tried to determine the source. All i could find was where it was dripping onto. The coolant, was leaking on the area behind the belt on the harmonic balancer.
If it isnt the harmonic balancer its the lowest pully to the ground and in the center of the engine.
I am not sure where the water pump is, as some have thought it could be that, was recently replaced, this could not be a cracked block could it? As there was a time where pure water was run, and there were freezing temperatures. I did however drain all the water out before morning came, but who knows...
Thanks in advance for your help!!
Old Feb 5, 2008 | 11:13 AM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Coolant Leak On Harmonic Balancer Pulley...
The water pump is most likely leaking,,, it is located above the harmonic balancer and is bolted to the front of the engine. The water pump is driven by a pulley, this pulley is above the harmonic balancer pulley. You should probably replace the water pump. I have an '87 IROCZ, I have had to replace my water pump twice.
Old Feb 6, 2008 | 11:33 AM
Car: 1988 Camaro SC
Engine: 2.8v6
bump
Old Feb 6, 2008 | 03:36 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
This is the correct answer.
This was unnecessary.
Originally Posted by Shookum2004
bump
Are you looking for a second opinion? Or what?
Old Feb 6, 2008 | 08:06 PM
Damon's Avatar
The water pump has a small "weep hole" on it's snout where coolant will seep out when the front bearing seal of the pump gives up the ghost. You can't easily see this hole with the water pump pulley installed so it can be a bit of a head scratcher to a novice who hasn't experienced a small block Chevy with a weepy pump.
You already got good advice on this, above.
Old Feb 6, 2008 | 10:08 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
get a small insp. mirror , flashlight , and check it out . thats the only place a coolant leak could be from .
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
Magman
Sep 13, 2015 12:14 AM
