Where is the fuel rail
Old Feb 5, 2008 | 03:14 PM
RedWind's Avatar
Car: 1991 Chevy Camaro RS
Engine: Stock V6 3.1L MFI
Transmission: Stock Automatic
I am looking for the fuel rail to test the pressure. I cant seem to find the nipple to put the gauge on can some describe where it is. I have a 1991 Camaro RS 6cyl 3.1l MFI
Old Feb 5, 2008 | 08:12 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Where is the fuel rail
i'm not certain but i cant remember ever finding a schrader valve on a third gen
Old Feb 5, 2008 | 08:33 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
On my TPI the schrader valve is on the fuel rail on the passenger side. I've seen it also on a 2001 GMC with a 4.3 in the center of the engine towards the back. It is always on a metal fuel line somewhere. Have not had a chance to search a 3.1 b4. But if it is there, you should be able to find it on a fuel line somewhere. Using a flashlight doesn't hurt when searching. I would start at the forward most fuel injector on each side and work your way back.
Old Feb 5, 2008 | 09:55 PM
Crux's Avatar
Car: 1987 Camaro
Engine: V6 2.8L
Axle/Gears: stock?
This is where the nipple to test is...look around here.
Sorry I don't know how to describe the exact location..and can't take a pic at the moment.
The pic was found with google and the engine isn't mine:
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
