which tach wire is which
Old Feb 7, 2008 | 02:38 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
I got this tach free from a friend that was at a rally and some kid freaked out on the tach for some reason and asked if any one had wire cutters my friend happened to be the closest one with a leatherman. I did figure this out at one point and I understand that they are power, ground, illumination and signal, i don't understand where to get a dampener and where to tap for the signal. here is a pic
Old Feb 7, 2008 | 03:23 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: which tach wire is which
red=hot (in fuse box) black= ground(to metal frame) yellow= hot for tach light(fuse box to fuse thats hot only when ign. switch is on) green= tach side on dizzy,hth jimmy
Old Feb 7, 2008 | 06:55 PM
mxcrazed's Avatar
Engine: None
Transmission: none
well yes and no. i knew where to get power and ground and illumination, didn't know which was which though. where on the dizzy? where to get a dampener so that the needle doesn't jump all over the place.
thanks jimmy!
Old Feb 8, 2008 | 08:45 AM
1fastam's Avatar
Car: 1991 transam
Axle/Gears: 4:10
there are 4 wires going to the coil mine are pink and white the back two go into a wire loom, theres a connector ,gray with white wire this should be where you hook into.later jimmy
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
stalkier
Aug 7, 2015 04:49 AM
