Temperature Gauge + Water Pump
Old Feb 9, 2008 | 10:51 AM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
I tried installing an aftermarket sunpro temperature gauge yesterday. I used teflon and everything and the water pump started leaking. Any suggestions? I have the correct sized fitting
Old Feb 9, 2008 | 02:12 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Temperature Gauge + Water Pump
wheres it leaking from?
Old Feb 9, 2008 | 02:14 PM
bummys_hotrod's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 7.5 3.73
I had the same problem, I ended up stripping the adapter, so i used the other adapter and put it in the head. or go to a hardware store and get a stronger adapter. The brass is to weak.
Old Feb 9, 2008 | 02:36 PM
robster66's Avatar
Engine: 305 T.B.I.
My adapter is not stripped and I think it's leaking out of the fitting that goes into the water pump because there are 2 fittings one that goes into the other fitting and the one that goes into the pump itself. I tried like 3 different times and just finally gave up and put the original plug back in
Old Feb 9, 2008 | 05:08 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
find the thread lok for pipe fittings i have never heard of it leaking and they have it at the home depot
evilstuie
Jan 9, 2020 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
