March Power Steering Pulley
Old Feb 10, 2008 | 07:41 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Has anyone put this type of after market bracket and pulley set on their third gen and if you have what problems did you run into?
I bought this set and the directions are very vague.
Old Feb 10, 2008 | 06:58 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Re: March Power Steering Pulley
I have that same setup along with the pulley on my car with the v-belt and yes the directions are a little vague, but it does work good. The biggest challenge is the bolts that are behind the pulley somewhat. I had to thread them in by hand and getting them started was a bit of a challenge. If you have the pulley off then put the bracket on then maybe put the pulley on if you are changing out that pulley. Makes a nice setup.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
