HP potential
Old Feb 13, 2008 | 11:46 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
HP potential
have a 350 factory bore honed, new rings, new bearings.
stock heads with valve job and resurface casting #10110810
high swirl intake ports.
lunati cam part #60101 .454in .468ex 213* 219*@.050 256*/262*adv LS112* 108*cl
but i have valve springs from a summit cam part#pl11p0414sr with 204*/214*@.050 .420in .442ex
holley stealth ram
accel 24lbh injectors
kirban perf afpr 43.5psi
msd blaster coil
commander 950 ecu
stock manifolds
custom ram air
dynotune n2o kit
what do you guys think this combo is puting out
or will run?
aharvel50
Sep 21, 2015 07:31 PM
machinist21
Sep 5, 2015 03:03 PM
dyeager535
Aug 28, 2015 08:10 AM
neekolzun
Aug 24, 2015 04:59 PM
