Rusted Parts.
Rusted Parts.
I did some cleaning in my garage this weekend and realized I had left some motor parts exposed to the elements throughout the winter and they had some rust build up. I was just wondering how much harm does this do to the parts? I plan on removing the rust but what would be the best way to do that without affecting the parts? Thanx ahead of time with any suggestions. Oh, also what would be the best way to preserve them so this doesnt happen again?
Re: Rusted Parts.
For any mating surfaces and especially on the cam use a rag and brake cleaner. Should remove most if not all light surface rust. For any non mating surfaces or anything not critical use steel wool and hope there is no pitting in anything.
Re: Rusted Parts.
I wouldn't trust a cam with any significant amount of rust on it. Throw it in the trash and get a new one. The lifters too, unless they're rollers, and have no rust.
Intake and heads don't too much matter.
The quarter car wash does a surprising job of getting light surface rust off of castings, tin, and accessories.
Paint them afterwasrds; maybe with some POR-15 or similar before the regular engine enamel.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Rusted Parts.
You can spray a camshaft with WD40, then wrap it up in a garbage bag for storage.
I'd use some green scotchbrite on just about all of those items. Just scrub them. Or for hard to reach areas, get some naval jelly or "rust dissolving" liquid and just spray it on and rinse it off. Spray paint the heads/intake, except for mating surfaces.
tcflint
Sep 27, 2015 05:58 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
