what should i expect?
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
i just dropped off my block with my machinist today
ordered the 383 stroker kit (eagle)
10.4:1cr
allum patriots 64cc chambers
190cc int runners
2.02 1.60
cnc bowl blended and ported
lunati vodoo 60103
will be running 1.6 ss roller rockers
hsr intake
30lbhr injectors
stock throtle body
shorty ceramic headers
700r alto race frictions 3-4 9 clutch pak corvete servo
custom shift kit
2400 stall
3.73 gears
what do you think my et's will be with this engine
10.4:1cr
190cc int runners
2.02 1.60
lunati vodoo 60103
hsr intake
30lbhr injectors
stock throtle body
custom shift kit
2400 stall
3.73 gears
Transmission: 4L80E/4L80E
Assuming a proper tune and decent traction, should be in the 12's.
You might want to go for more stall.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: what should i expect?
glad to see you step up on the cam and go with those patriot heads. That motor should haul some butt.
i'd have the shop zero deck the block, so you can run a standard .039-.040" head gasket. This will give you best compression and quench height, all good for more torque and power and less detonation prone.
injectors look good, stock throttle is a bit small but will work for now. Shortys will give up alittle power as well but should still be a good running motor.
i'd say your gonna put down near 340whp and run mid to lower 12's on a good day. I'd like atleast 2800 stall in that car tho. 383 has some torque so you dont need a huge converter but 2400 is alittle off the meat of the power band
Car: 86 iroc
Engine: 383HSR
yeah i was looking into the yank convertors a buddy is running one in his 12sec ssr
ZZ3Astro
Aug 13, 2019 12:57 AM
