SO my spark knock wasnt exactly...a spark knock
Old Feb 22, 2008 | 12:30 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Just found out today, quite to my suprise that my tranny mount was kinda on its way out and here i was thinking the shaking was a spark knock.....well......i decided to do a nice u-turn today and light em up and in doing so i must have helped my mount take its final blow. Trannys fine, nothing major but i didnt realize it until i was driving and my shifter just kinda lifted up out of my hand lol. so when i got it to school i threw it up on the lift and made sure my motor mounts weren't the culprit, those are fine, but the tranny mount is definitely done for. Called up checker and the new mount is only 10$, so i might just throw it on, until then i just have to baby the gas pedal.
Anyone done the mounts on this before? any tips? is it hard? better yet, can i do it in under 2 hours? if so ill just do it at school
Old Feb 22, 2008 | 12:43 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: SO my spark knock wasnt exactly...a spark knock
trany mounts are cake.. few bolts remove the cross member take old one off put new one on reattach to trany bolt up member 15 min a the most..
Old Feb 22, 2008 | 01:02 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Lol, I guess thats one good thing about a manual trans. When my trans mount let go, I didn't know about it until I took off from a light hard, and the trans lifted up and smacked the tunnel.
Old Feb 22, 2008 | 02:01 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're going to replace it, use a poly mount so you'll never have to worry about it again.
Old Feb 22, 2008 | 06:13 AM
IROCWPB's Avatar
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
It took me 5 stock-type mounts being broken within hours of installation after I put my 383 in to realize this. IMO the people who make the stock type mounts and sell them as worthy replacement parts, should be shot.
Old Feb 22, 2008 | 11:07 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
i would agree with a 383 u need an aftermarket mount.. then again i got a 2.8 so i don't realy need an aftermarket one..
Old Feb 23, 2008 | 11:48 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
yeah it was definitly easy to fix, unfortunately im kinda broke right now cuz i just had to shell out money for school, so i just went with the cheap one from checker, i'm gonna go through and replace all my mounts soon with the poly ones but for now this works, still lifts a BIT but i think thats my engine mount, i need a new driver side one soon lol
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
efiguy
Sep 27, 2015 01:30 PM
