Bore question
Old Feb 23, 2008 | 02:15 PM
Rempa's Avatar
Car: 1987 IROC Z28
Engine: 305TPI
Bore question
Greetings,
When you grind your crankshafts journals, does it affects the crankshaft sprocket? I need to remplace it and I'm wondering if I should buy a stock one or will the bore affect the center size of the sprockets?
Thank you.
Old Feb 23, 2008 | 02:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The normal grind is just the main and rod bearing journals. They won't touch the snout. If there's damage, that would require welding to build up the material so it could be ground back to the standard size. I've never heard of it being done, though.
84z96L31vortec
Aug 20, 2017 12:16 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
