high squeling problem
Car: 85 berlinetta
Engine: 350 carb
Transmission: 4 speed auto
so when i start up my car for the first 10 seconds or so my car has this really high squealing noise coming from the engine im guessing it a belt but im not sure any tips?
Transmission: 4L80E/4L80E
Check your belts for proper tension, and the belts and pulleys for wear. Alternator is the most common culprit, power steering next. There are three bolts that need to be loosened for the PS pump, so make sure you get them all.
