many questions
Old Feb 26, 2008 | 11:53 PM
Hartmann's Avatar
many questions
hello all i recently bought a chiltons manual for my 1986 iroc camaro and needed clarification on some things.
How would one remove all the ground effects on the camaro?
How would one remove the rear hatch shocks.
How would one remove hood shocks?
How hard would it be to remove all the iroc rims and repaint then stock what color would that be?
Sorry all for the avalanche of questions but this board is very helpful...
Old Feb 26, 2008 | 11:55 PM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Re: many questions
ground effects are only held in by screws and those annoying little plastic pop things.
Old Feb 27, 2008 | 06:09 AM
Re: many questions
Open hatch; support; unscrew. Note: the hatch is HEAVY!!!! And I don't mean, just, heavy; I mean, HEAVY!!!! Like, a couple hundred lbs. Don't think you're going to stand there and hold it with one hand while undoing the hardware with the other. You can SERIOUSLY HURT YOURSELF, and/or your car, if that thing gets loose and falls on you.
How would one remove hood shocks.
Open hood; support; unscrew. At least, that isn't quite so heavy; only 70 lbs or something, if it's a steel hood.
Same as any other rims.... jack up car, rotate lug nuts counterclockwise, remove tires, clean, mask, squirt.
Old Feb 27, 2008 | 09:14 AM
Hartmann's Avatar
Re: many questions
would i have to jack up the car to access the plastic pop things. i have removed all the screws in the left side that were visible but it wasnt going anywhere? got an idea of where i can look?
Old Feb 27, 2008 | 01:25 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: many questions
If you're going after the side GFX there's one stud bolt that you have to remove the rear seat plastic to get to.
Old Feb 27, 2008 | 02:09 PM
burtreynoldss's Avatar
Car: 1989 Trans Am
Axle/Gears: 3:42
Re: many questions
get a buddy for the hood and hatch shocks, just did mine, that hatch is freakin heavy
Old Feb 27, 2008 | 02:21 PM
89ram_air_iroc's Avatar
Car: 1989 Camaro Iroc
Transmission: Built up 700R4 2500rpm stall
Axle/Gears: 3.42 Torsen Posi 4th gen
Re: many questions
Heres a link to a good article on how to clean up and refinish your rims so they are like new.http://www.austinthirdgen.org/index.php?pid=9
Not sure on stock color, believe most are some sort of gray.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
