Cant get a steady idle? Help plz
Old Feb 28, 2008 | 09:36 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
Hello, I just want to ask if anyone knows what may be happening to my car.
When the car is in Park and running the idle goes up and down from 900-1100rpms, sometimes "like now" it drops down more low perhaps 800rpms or lower, enough to sound if it were to die but it does not , instead jumps back up to 1100rpms and hovers around 1000rpm "unsteady idle".
Im thinking it just may be a air/gas problem? maybe timing? I dunno, but the car has also been suffering from lower then normal MPG also
any ideas would be great, Lates
Old Feb 28, 2008 | 10:19 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Re: Cant get a steady idle? Help plz
84.....hmm, computer-controlled Quadrajet carb?
Does the motor diesel at all when you shut it off? Check all the electrical connections with that carb...and if it has some kind of IAC/Air bypass valve, try disconnecting it and restarting. Also check that your base timing isnt too low. Typically surging is a symptom of either a rich a/f mixture, too low base timing, too low base idle setting, or a faulty sensor reading, typically TPS, thats causing the computer to keep playing with the IAC valve trying to achieve a stable idle but its too out of spec.
Old Feb 29, 2008 | 12:03 AM
Engine: V8 350 ci
dopey me forgot to put that this is for a 1991 geo strom 1.6l, I thought I someone might know but I do beilve it may just need to have the timing done and the belts replaced.
Old Feb 29, 2008 | 09:24 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
palm bay close to miami?
Old Mar 2, 2008 | 08:25 AM
cam/am's Avatar
get some carb cleaner and take the idle air control from the engine.un plug it.take it out.spray the idle air control until it is clean.spray the hole it goes into too.screw it back in and plug it back in.real simple.you will find that its covered with gunk.i will run smoother .promise. cam/am
junior419
Apr 7, 2025 11:35 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
