Intro/ question/ pics
Old Feb 29, 2008 | 11:55 AM
gigglehush's Avatar
Hey I'm new to the forum. I'm 19, living in California, oh and I'm a girl
I've always loved Camaros and Birds but have not had the chance to own one untill recently when I got a 1990 Firebird SSA. It has 17 in Edelbrock rims, flowmaster dual exhaust, t-tops, great interior/exterior, custom GTO hood
I love the car but, obviously, it has..issues. I put $2000 worth of work in the engine alone, now i just need to get the tags up to date. After having the exhaust leak fixed it passed smog but my mechanic said the oil pan is leaking (greeeaaat). So my question is, when I drive the car the oil gauge goes up and down like crazy. It will be fine while I'm on the gas but as soon as I start to slow down it goes down past the half way mark. Is this being caused by the oil pan leaking or is it something else?
Thanks!
Hope these pictures show up...
Old Feb 29, 2008 | 12:16 PM
cameron7710's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Intro/ question/ pics
welcome to the form and nice car also i dont think the pan leaking sould a be a problem just make sure u watch the oil levels cause my camaro has a small leak cause when my sister owend it she ran over a big tree branch and pulled it home with her and its fine
Old Feb 29, 2008 | 12:28 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Oil pressure is relative to RPM.
THe pressure will drop as the engine speed slows down, so it seems normal.
Do you happen to know the amount of pressure you have at idle? That is
important to know, as well as pressure at cruise and maximum RPM used.
Keep an eye on that leak and oil level. If the oil level gets below the pump
pick-up tube, it's dangerous to the motor as it will have zero pressure and
volume.
Old Feb 29, 2008 | 11:25 PM
gigglehush's Avatar
Thanks for the advise...
volume.
I don't know the amount of pressure, not even sure how I would test that as I'm not a mech...
So the oil pan doesnt have to be fixed as long as I make sure the oil level isnt too low??
Old Mar 1, 2008 | 12:30 AM
KJZ28/TA's Avatar
Car: 2002 Camaro
Engine: :(
Cool...sweet car...looks way better than mine. Glad to see a girl is not in Mustang and in a product of the General!
Th oil pan leak is an easy fix...drain oil, pull pan off, clean it up, replace gaskets, bolt it up put new oil in. I have done it on my 78, had to take off the two engine mount bolts and jack the engine up an inch. Not sure if you have to do this for you bird.
Old Mar 1, 2008 | 01:37 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
as far as checking the pressure at idle, just turn the car on put it in drive, hold the brake and watch the gauge, it should level out, when you hit the gas, the rpms will rise and so will the oil pressure.
Make sense? lol its pretty simple, alot of things are overtalked and end up being really simple
BTW Welcome to the boards
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
