loud engine knocking
Old Mar 1, 2008 | 07:02 PM
88c@m@ro88's Avatar
its a 2.8l v6 when the engine is running its fine but when the gas pedal is pressed the loud knocking noise starts the lifters and valves are fine your can hear it from the air intake
Old Mar 2, 2008 | 09:20 AM
Re: loud engine knocking
Do a compression test.
Don't forget: remove all spark plugs, block the throttle wide open, make sure the motor is fully cooled down, keep the battery HOT (like, keep a charger on it constantly) so that the engine spins the same speed on all cyls, spin the engine long enough on each cyl until the gauge quits going up. Maybe 6 or 7 compressions or thereabouts.
Post the numbers you get if you don't know how to interpret them. YOu should see smoething like 160ish psi in all cyls, with no more than about a 15 psi variation from highest to lowest.
I'm betting you'll find either 2 adjacent cylinders with low pressure (like, 30 psi or less), or one cyl with VERY HIGH pressure (like, 40-50 psi more than the others).
Old Mar 2, 2008 | 10:09 AM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
what cause that?
Old Mar 2, 2008 | 10:26 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
valve seats, head gaskets, cylinder rings...
Old Mar 2, 2008 | 10:44 AM
2 adjacent low: blown head gasket
1 high: rolled exhaust lobe, broken exhaust rocker, etc.
Old Mar 2, 2008 | 10:51 AM
intex1982's Avatar
my car has the same loud knocking noise. running better then it ever has. well till the trans went out yesterday. made a pass with a 1.77 60ft and 12.940 1/4. but it would of been better if i had not shifted it at 4000 in to 2nd gear. but i have 3.73 and about 100 lbs heavier than last yr.
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
