Timing question
Old Mar 6, 2008 | 12:47 PM
AintEzBnMeee's Avatar
Car: '86 Camaro
Engine: 305 4bbl
Transmission: auto
Timing question
I have an '86 Camaro with a 305 4bbl carb. I guess its a CC Rochester Qjet since it has 2 or 3 different electrical plugs on it. There is no vacum advance on the distributer, so I guess its mechanical. Will all Camaros have a white/brown wire to disconnect in order to set the timing? I cant locate such a wire on the passenger side near firewall, then I read in a thread it may be on the drivers side. What indications will I get if I unplug the wire to let me know I have the correct wire unplugged?
Thank you
Old Mar 6, 2008 | 01:35 PM
Re: Timing question
With the carb system, that's not how you do the timing....
You have to unplug the connection between the distributor and the outside world.
There are 2 harnesses coming out of the base of the distributor; the one that goes up to the cap with 3 wires in it, and one that hangs free and has about 4 or 5 wires in it, and a big flat Weatherpak type connector. It usually hangs down behind the dist, between the intake manifold and the trans tunnel. You have to unplug that one to set the timing to the factory spec.
With the engine off, unplug that. Start the engine up. It will run terrible and light the Check Engine light. Check and if necessary set the timing. Turn the car off, hook the plug back up, re-start the engine, and the light should go out.
Old Mar 6, 2008 | 01:47 PM
Car: '86 Camaro
Engine: 305 4bbl
Transmission: auto
Re: Timing question
Thanks for the reply and the information...I will look for the wire harness you described...
Old Mar 6, 2008 | 02:11 PM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Re: Timing question
i have the stock balancer and timing cover and I'm just wondering how to read it the deep grove in the timing tab is 0*? and each piont is 2*? what is a good start for base timing?
Old Mar 6, 2008 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Timing question
Actually, it's electronic. There isn't any mechanical or vacuum advance provided by the distributor.
Base timing ranges from 0 to 6 degrees BTDC. Set yours to what the sticker under the hood says, and go from there. Most people see slightly better throttle response with 4-6 degrees advanced.
Old Mar 6, 2008 | 02:53 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: Timing question
there are no stickers on my car not even an single rpo ill try that but how do i read the timing tab?
Old Mar 6, 2008 | 03:59 PM
five7kid's Avatar
... how do i read the timing tab?
You had it right.
Old Mar 6, 2008 | 05:03 PM
mxcrazed's Avatar
Engine: None
Transmission: none
Re: Timing question
thank you
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
