can i convert my PS from serp to vbelt?
Old Mar 6, 2008 | 08:20 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
can I remove my serpentine pulley and replace it with a v belt pulley on my power steering pump?
are the press fit shaft diameters the same?
is the overall diameter of the pulley a big deal?
Old Mar 6, 2008 | 11:17 PM
ponieburner91's Avatar
Re: can i convert my PS from serp to vbelt?
just swap the pullys allu need is a pulley puller
Old Mar 7, 2008 | 12:24 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
Hey is this the type of set up you are talking about?
If so I would also know if this would apply to my application. Here is a link to an earlier post of mine. https://www.thirdgen.org/forums/tech...t=missing+belt
Thank you for your time!
Old Mar 7, 2008 | 02:55 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Maybe I'm not making myself clear.
That is what I want to do, just swap PS pullies. I just wanted to know if their is any differences in shaft diameter or pulley diameter I should be aware of? I have a custom PS bracket I put together so I can adjust depth of my PS pump as much as I want. (for supercharger clearance)
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
2012sergen11
Oct 13, 2015 07:38 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
