valve seals removal and replacement
Old Mar 8, 2008 | 06:14 AM
jrizza's Avatar
is it possible to replace valve seals without removing the heads ?
Old Mar 8, 2008 | 06:42 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: valve seals removal and replacement
Yes. The problem is that you have to remove the valve springs to get to them, and the only thing holding the valves in the heads are the retainers on the springs.
Some people say use compressed air into the spark plug hole, others put the piston at that cyl at TDC. Other people just fill the cylinder with some sort of soft pliable rope, like nylon. I figure the rope or rubber hose idea should be fine, just got to make sure the valve doesnt fall into the motor because I'm not sure how you'd get it back up without removing the heads, but I'm not as knowledgable about this stuff as other guys here are.
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 8, 2015 07:09 PM
