Shocked by plug wires. Does that mean they "leak"?
Old Mar 6, 2008 | 11:59 AM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
So, I have a rough running engine. Started around the time I redid the ignition setup and a few other things. Failed Mass. emissions I put on a set of used MSD wires.
When I touch the wires, if I get shocked sometimes, does that mean the leak? Not the ends but, the wires themselves.
-Dave
Old Mar 6, 2008 | 03:12 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: Shocked by plug wires. Does that mean they "leak"?
Idle motor in very low light. Open hood. If you see a lighting storm, change what ever is sparking.
Old Mar 6, 2008 | 06:42 PM
Damon's Avatar
Yes, you've got wire issues. You should be able to grab them anywhere along the wire or around the boots and not get a shock.
Old Mar 6, 2008 | 07:00 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As mentioned above. Open the hood in the evening or night time and start the engine. If you don't see a bunch of sparks, use a spray bottle and mist water over the wires. Everything should light up if the wires leak.
It sounds like you have leaking plug wires. I have yet to get a shock from mine and really don't want to. I use a MSD HVC-2 coil which packs a whopping 2 amps of power. It would be enough to knock me back on my butt if I get shocked.
Leaking plug wires should cause a miss because the spark energy is leaking to ground before it gets a chance to fire the plug. Plug doesn't fire and raw fuel goes out the exhaust.
Old Mar 6, 2008 | 10:32 PM
PV9685's Avatar
I didn't notice anything "dry", then I sprayed them and not much happened at first, but the car idles great for like a minute and then goes bad and misses even at high speeds/loads. But, the lighting storm went full effect.
thanks guys! I thought that the wires would be trouble-free, but I assumed too much of a used product that was lying around for years. Too bad, it's like a hundred bucks for a new set of 'em Time to go for a cheaper set.
-Dave
Old Mar 7, 2008 | 12:48 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
This is a valuable real life example of what not to do. I have done the same thing, it is prompting me to check my own wires. I have a slight "clicking" which could be a cylinder missing, I'm excited to learn. Every day that I drive my Firebird it makes it easier to sell my Jeep.
Old Mar 7, 2008 | 03:59 AM
Pat Hall's Avatar
For a cheaper set of wires I recommend getting a set of Borg-Warner "Select" wires. I've had these wires on mine for over 100K now without a single misfire yet. Think I paid around $35-$40 for them.
Old Mar 7, 2008 | 07:56 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I would not go any cheaper than stock AC Delco. Anything less is a waste.
Stephen did you know that a rock falling 1/4 mile, takes 9 Sec and travels 200 mph. If no air resistance,(in a vacuum).
Old Mar 7, 2008 | 08:14 AM
AlkyIROC's Avatar
Car: 87 IROC L98
32 feet per second per second, yes
Old Mar 7, 2008 | 07:48 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by pandin
...Stephen did you know that a rock falling 1/4 mile, takes 9 Sec and travels 200 mph. If no air resistance,(in a vacuum).
...And every one of us are traveling at over 66,000 miles per hour as we ride on planet earth around the sun. (fact)
Old Mar 8, 2008 | 12:01 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
no wonder im getting carsick......
Old Mar 8, 2008 | 07:21 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
So Stephen were you speeding up or slowing in the 1/4 during that 9 sec?
Wouldn't it be easier if we could just put on the brakes?
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
SG91camaro
Sep 5, 2015 10:27 PM
