Need more RWHP!!
Old Mar 8, 2008 | 04:45 PM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Need more RWHP!!
Ok I have an 84 Z28 I need more power I will be getting some SFC for strength due to having t-tops but I would like to add some power to my stock z28 5 speed. I do have a 350 TBI in my 88 Blazer I was thinking of swapping in and putting the 305 in the blazer should I? \
What do you guys think I should do? 350 swap or bolt on performance or both?
I'm looking for around 300 to 350hp on a carb.
Old Mar 8, 2008 | 04:56 PM
Car: 1986 Camaro
Engine: 350 v8
Re: Need more RWHP!!
Anyone???
Old Mar 8, 2008 | 05:46 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
It would be a good swap depending on if you want the power loss in your blazer. your t5 might not like the 350 if you do a lot of work to it, and ditto if you have a 10 bolt.
Old Mar 9, 2008 | 10:53 AM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
FULL exhaust first!
Old Mar 9, 2008 | 11:07 AM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
You wouldn't want the lost power in that blazer... trust me, my buddies got a K5 also
Great idea on exhaust setup first
Old Mar 9, 2008 | 06:35 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Your t5 (and in fact mine) are not meant for that kind of power. Im between the range of 300 to 350 hp I'd say...I haven't gotten a dyno yet but I'm easily in that range and I got a rebuilt t5 that since my v6 swap I've put 1k miles on. Just remember you'll have an easier time gettin that 350 to your horsepower range over that 305. Exhaust would be good, but its just a start. Look at my sig and see what I have done to my car...it'll give you some good ideas of where to start
Old Mar 9, 2008 | 09:55 PM
Car: 1986 Camaro
Engine: 350 v8
I wanna get rid of the weak points so what should i do about my t5? I still want to have a 5 speed.
Old Mar 9, 2008 | 10:39 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Go for the killer t56
Old Mar 9, 2008 | 11:10 PM
Car: 1986 Camaro
Engine: 350 v8
Ok I have an off topic ? Why can I see your sig bit no one else's nor my own
Old Mar 10, 2008 | 05:39 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Yours is on the top...and can only be seen on the top post
Old Mar 10, 2008 | 10:01 PM
Car: 1986 Camaro
Engine: 350 v8
I can see Joeblue83's sig
Old Mar 10, 2008 | 10:40 PM
Uglybronco's Avatar
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
.... He meant your 1st post only I think. I don't have one but I believe that's how it works.
Old Mar 10, 2008 | 10:41 PM
kerplunk318's Avatar
I agree^
a 305 in a blazer... ehhh you would be better off picking up a junkyard 350 and rebuilding it for the camaro, theyre a dime a dozen.
Old Mar 10, 2008 | 11:17 PM
84TransAm383's Avatar
i would swith to the 350 defitly i did and dropped 1.5 sec on et. If your not building it for racing weekly simply add things such as a bigger exhaust, manifold, bigger carb, 3.73 gears with 295 tire, and put a shift kit in the tranny that can with hold 400 hp, and go with aluminum heads.
its alot of money to get 350 hp so sumtimes its better to just buy a new crate motor for 4 or 5 grand
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Yes, as can I. I have a signature and I'm not technical with these things so I'm not too sure why you can't see mine or others...
Old Mar 13, 2008 | 02:21 PM
Car: 1986 Camaro
Engine: 350 v8
Ok back on topic I think I just might buy an engine
I was thinking of one of these
http://gmperformancepartszone.com/35...html?cPath=1_2
http://gmperformancepartszone.com/ba...html?cPath=1_2
http://gmperformancepartszone.com/zz...html?cPath=1_2
Old Mar 13, 2008 | 02:30 PM
Car: 1986 Camaro
Engine: 350 v8
where should i look to find a t56?
ZZ3Astro
Aug 13, 2019 12:57 AM
Hawk312
Aug 22, 2017 08:55 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Nervous2
Oct 8, 2015 10:53 PM
BBSDesigns
Sep 22, 2015 03:08 PM
