Idle Problems
Idle Problems
Hello, i have a 91 LO3 Auto and i have idle problems.
it stays at around 600 rpm, then i hear a *click* then the rpms jump a few hundred thengoes back to normal. *click* jumps up a few hundred then back to normal. *click* jumps up a few hundred then back to normal.
is it a vaccum leak? what could it be? i need to smog this thing soon and im sure it would help to stop that *click*
thanks!
thanks!
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Idle Problems
do you have it set on defrost? ifso its the air compressor clicking on and off put it on vent and see if the clicking stops,later jimmy
