Odd noise from ???
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Odd noise from ???
A while back I started to hear a noise coming from the rear of the motor. It kind of sounds like a playing card flapping on bicycle spokes. Not much vibration though. At first it was only at start-up when I would rev the engine. It would then slowly fade away. Now I'm hearing it more frequently. I hear it wheather I'm in motion or stopped. Any ideas?
Re: Odd noise from ???
Thats where I'm going to start. I put in a set of exhaust manifold gaskets a couple of years ago. Probably time to check the bolts.
Take those out of there.
Use a Roloc pad to clean the manifold surface, and a flat file GENTLY to dress it flat, and to dress the head surface; and put it back together with no gasket, like the factory did. End of problem.
sjorgens
Oct 1, 2015 07:54 PM
