help with speedo
Old Mar 18, 2008 | 10:01 AM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
help with speedo
hi, i have a 91 formula that we stwitched over to a carb setup. in the process we got rid of the computer and a bunch of uneeded wires in the engine bay. Do i need the computer for my speedo to work? I see a purpish wire coming from the tranny what is that?
Old Mar 18, 2008 | 11:54 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: help with speedo
The purple wire is for your VSS. I'm not a 100% but you shouldn't need the computer for your speedo you should just be able to run your Vss wire directly to the speedo and be good to go.
I think originally the VSS goes to the computer first and is then sent to the speedo, so by cutting out the computer you just broke the circut but should be an easy fix.
Old Mar 18, 2008 | 02:01 PM
specvgini's Avatar
Car: 1991 Formula
Engine: 5.7
i'll try and reconnect the wire and see what happens.. i'll take some pics of the engine bay and whats going on..
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
