my car won't start after engine is warm
Old Mar 19, 2008 | 07:46 PM
89RedIroc's Avatar
I need some help guys. I am new to the world of fuel injection. I bought an 89 Camaro Iroc Z with the 5.7L TPI motor. The car is all stock. I love these cars but i just don't know that much about them. When i bought the car it ran fine. a couple of days later after buying the car, I started having issues. The car starts right up when the motor is cold. It idles fine and does not stall. The problem is: after the motor is warmed up, if i shut the car off and then try to restart the car, it will not start. The motor cranks, it just doesn't start. Now if i pull the air cleaner assembly off and spray starting fluid in the throttle body it will start right up. So to me it wouldn't be an ignition problem but i am unsure because i really don't know much about fuel injection. I have always owned carbed cars. Hopefully someone can give some ideas on what this could be.
thanks,
Mike
Old Mar 21, 2008 | 08:06 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: my car won't start after engine is warm
It sounds like it is running the F/P off of the oil pressure switch because the relay is bad.
Get someone to stand behind the car while you turn the key on and listen for the pump to run for 1.5 seconds at key on. (key needs to be off for at least 2 minutes first)
If the relay goes bad, it uses the oil pressure switch as a backup.
When the oil heats up there might not be enough oil pressure to turn on the switch during cranking, but after the engine starts there will be.
That's probably the reason the car was up for sale; nobody could figure this out.
Old Mar 21, 2008 | 08:39 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Sounds like the fuel-pump relay isn't priming the pump. When warm, the oil is thin and takes longer to build pressure when cranking.
Old Mar 21, 2008 | 11:31 AM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
My exact problem dude. i've been told its the fuel pump going bad. then i was told maybe its a leaky injector causing a flood, sorta like a carb would do? Taking it to a shop soon to get a final answer!! You should do the same, its definitely the fuel system. Let me know man. GOOD LUCK
Okay gentleman.... sounds logical,,, but how do we FIX IT NOW!!
Hmmm.... sounds like that may be it guys. so how do we FIX IT!!!
Old Mar 22, 2008 | 08:51 PM
89RedIroc's Avatar
thanks for you help guys but i have another question. I will check out the fuel pump relay but which one is it? I looked in the engine bay and i see a couple of different ones. One is near the battery and then there are two on the firewall on the driver's side. Is it one of those or is it somewhere else? thanks a million.
Mike
Old Mar 23, 2008 | 08:05 AM
Engine: 350 4BBL
Mike
They change up the mounting of the relays on different year models.
Here's a pic of the 3 relays on the firewall of my '88.
The F/P relay is the "rectangular" one. The other two are "oval" shaped.
Old Mar 23, 2008 | 08:23 AM
Engine: 350 4BBL
Originally Posted by Supervisor42
...Get someone to stand behind the car while you turn the key on and listen for the pump to run for 1.5 seconds at key on. (key needs to be off for at least 2 minutes first)...
Do this test first. If the pump runs at key-on, it's not the relay.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
