LT1 Starter Corvette or F-body
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
I've look at both of them, but I can't figure out if either would be much better.
F-body Starter P6470
Y-body Starter 17124
They appear to wear about the same; however, the corvette one is cheaper by $30. The f-body starter has a normal nose, but the corvette does not. They appear to have similar electrical connections.
Also does any one have the part numbers for the shorter bolts?
