timing and octane level
Old Mar 20, 2008 | 11:13 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
well I'm thinking about bumping my timing from 8* to 10* on my 350
its got iron eagles 180/64 274 comp cam, rpm air gap, holley 600 cfm 4 barrel, and msd distributor
if i bump it up will i have to switch to 91 or can i still stay in the 87-89 octane range?
Old Mar 20, 2008 | 11:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Timing and octane don't have anything to do with each other (people often advance their timing too far and "fix" that by using higher octane gasoline, but that's counter-productive).
Initial timing is a poor way to set the timing. With the equipment you're running, you really set the "total mechanical" timing rather than the initial. If doing that raises your initial to the point that you get starter kick-back, then you need to increase the amount of advance your mechanical system provides.
Octane choice should be made based on compression, not timing.
Old Mar 21, 2008 | 04:16 PM
mbolte's Avatar
Car: 1987 Camaro
Re: timing and octane level
alright thanks man, talked to a friend and he said something about that so i figured i would ask
bryan623
Mar 22, 2021 06:43 PM
Thornburg
Aug 25, 2015 01:46 AM
jbd1969
Aug 17, 2015 07:06 PM
355tpipickup
Aug 13, 2015 07:35 AM
