Smog Delete Pulley?
Old Mar 23, 2008 | 12:05 PM
mouthforcombat's Avatar
Car: '86 Iroc Z
Smog Delete Pulley?
So I've seen this term, "Smog delete pulley" thrown around a little bit and I don't understand why one is necessary. I bought my iroc dismantled down to the pistons, serviced everything and put it back together, minus all emissions and a/c... I have two belts running my alternator, powersteering, waterpump, and of course my crankshaft pulley. No emissions pulley, no A/C, nothing... Did I do something wrong? *confusion*
Old Mar 23, 2008 | 12:14 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Smog Delete Pulley?
It's only needed for single serpentine belt systems, but it's not REALLY needed at all, easy to bypass it.
Old Mar 23, 2008 | 12:18 PM
Car: '86 Iroc Z
Thank you.
Old May 10, 2008 | 08:22 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Engine: LT1 w/lt4 hotcam kit
Transmission: stage 3 700r4
Axle/Gears: posi 3.42
whats the easiest way to bypass the smog pump if u dont need the pulley
Old May 11, 2008 | 07:00 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
It fills up the empty space left when the air pump is removed....just looks better IMHO.
jaridjohn
Oct 5, 2015 07:01 AM
