Can someone identify this sensor??
Old Mar 23, 2008 | 01:55 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
I've been gradually putting my 355 together which was originally a LB9. I have found this sensor with the wire attached in the engine bay and cannot for the life of me figure out what it is. If anyone can let me know, I'd greatly appreciate it. Thanks
Old Mar 23, 2008 | 02:00 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Can someone identify this sensor??
looks like a funky/broken O2 sensor to me.
Old Mar 23, 2008 | 02:07 PM
92WhiteZ28's Avatar
Car: 92 RS, 87 IROC, 89 GTA
Engine: LO3, LB9, L98
Transmission: 700R4 X3
Axle/Gears: 2.70, 3.30, 3.27
Old Mar 23, 2008 | 02:23 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
I don't think it's a O2 sensor a 13 mm wrench fits it, so it's pretty small. I was thinking it might be some kind of temp sensor, but really have no idea. There isn't a hole in the bottom or anything just flat. It does have the connector attached to it pictured which is only one prong. Any other ideas??
Old Mar 23, 2008 | 09:20 PM
kanexpl's Avatar
Car: 94 C1500
Engine: 353 TBI
Axle/Gears: 4.10
That is a egr temp switch. It changes state when the egr valve is open on a maf tpi car. Map cars use the amp sensor to tell with the egr valve is open.
Old Mar 23, 2008 | 11:49 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
yep egr temp switch lets the ecm know how much the egr is flowing %
Old Mar 24, 2008 | 09:23 AM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Thanks guys, I don't have the egr anymore so noo need for that either I take it.
SS-EXPRESS
Sep 28, 2015 09:14 AM
tattmann
Sep 27, 2015 05:20 PM
efiguy
Sep 27, 2015 01:30 PM
wstephan96
Sep 25, 2015 04:28 PM
