Miss @ #2 Cylinder
Old Mar 23, 2008 | 06:36 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Miss @ #2 Cylinder
Hey folks, My engine has developed a miss that I have isolated (by pulling plug wires at the distributor) to cylinder #2. The plug is getting spark, but the plug is wet with gas when removed, and the header is cooler than the others. I will next pull the valve cover to inspect the valve-train. Whatcha think, broken valve spring, or pushrod, or rocker, or all three? No strange noises from the engine, just rough running from not hittin' on all 8 holes. Thanks! -Bill
Old Mar 23, 2008 | 07:21 PM
Damon's Avatar
Re: Miss @ #2 Cylinder
Before you tear it apart run a compression test on #2 and as many of the others as you like. If #2 is abnormally high or low you know something's up with that cylinder.
Old Mar 23, 2008 | 07:52 PM
afida15's Avatar
if the plug is wet with gas then you wouldnt have a problem with the valve train would you? i would look at the distributor cap first, maybe a bad wire?
Old Mar 23, 2008 | 08:27 PM
Burnout91's Avatar
Engine: Modded L98
Thanks for the replies. I know (99.9999%) its the #2 cylinder because I performed a cylinder power balance test. I think I have ruled out ignition, I even put a new plug in that cylinder, I ohm'd the wire, it was one of the lowest(!), I stuck a spare plug in the #2 wire, grounded it, and fired the engine, it sparked like a champ. It still seems like an ignition problem, but... Yes, it seems like at least the intake valve opens, or the plug wouldn't be wet with fuel. Maybe the exhaust side...I haven't really thought it all through. I WILL find the problem, just thought I would bounce it off of you folks. 'Been thinkin' about that 383" short block anyway..... -BIll
Old Mar 23, 2008 | 09:00 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
i would recomend a compression and leakdown test. It would seem that you have fuel and spark. You may have a problem with compression on #2.
Old Mar 23, 2008 | 09:58 PM
Burnout91's Avatar
Engine: Modded L98
Yep, I agree with the compression diagnosis, at least for now. The heads are the latest component in the combo. Bill
Old Mar 25, 2008 | 09:07 PM
Burnout91's Avatar
Engine: Modded L98
Broken intake rocker stud. Fortunately (??) at the threads on the rocker end. -Bill
Bubbajones_ya
Jul 6, 2024 08:32 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
camaro1185
Oct 26, 2015 06:51 AM
L98GTA87
Oct 19, 2015 10:43 PM
