extra radiator hose
Old Mar 24, 2008 | 03:18 PM
Hartmann's Avatar
extra radiator hose
my 86 camaros radiator has an extra outlet hose that is above the trans cooler and under the pressure relief hose. the previous owner put a black rubber cap on it and clamped it the cap is cracked anyone have an idea where i can buy another, what the hole would be and is their a better solution to my problem them re capping it.
Old Mar 24, 2008 | 03:38 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: extra radiator hose
sounds like your talking about the return for the heater core.
Old Mar 25, 2008 | 11:06 AM
Hartmann's Avatar
o really how hard would it be to run a hose for the heater core?
Old Mar 25, 2008 | 11:21 AM
gapimpin's Avatar
Engine: 383 LT1
if your heater core isnt hooked up you would just run a hose from the water pump to the core then from the core to the radiator.... if its not hooked up though chances are the core is busted.
Old Mar 25, 2008 | 01:25 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
the inside of that port on my factory radiator is threaded i put some teflon paste on the apropriate sized plug and problem fixed
Pac J
May 17, 2020 10:44 AM
Veaceonee
Sep 29, 2016 08:15 PM
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
Night rider327
Oct 9, 2015 09:25 AM
