confused on base timing
Old Mar 26, 2008 | 01:02 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i've read on here to unplug 4 wire plug by dizzy,then i've heard to unhook est wire when warm, then cold. after all that, set it to 0' to 5 degree advanced ? so what is the true way?
Old Mar 26, 2008 | 02:47 PM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
Re: confused on base timing
Unhook the EST wire. Its a brown wire with a black stripe, and located toward the passenger side of the car; by the blower motor. It should stick out from the main loom going to the ECM.
I think the base timing is 0* for TBI cars.
Doesn't matter if the engine is cold or warm, AFAIK.
Dave
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
86IROC112
Aug 21, 2015 07:20 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
